removing dp off 94 3.4
Hey I blew out a freeze plug under the manifold on the passenger side. I managed to get a repair plug in but that only lasted about 6months. I've gotten all but the top dp bolt on the top of the dp on the passengers side. Please help me on how I can get this out
Soak the dp bolt with po (penetrating oil) and heat it up a lot with a bt (blow torch) then try and grab it with a bew (box end wrench) or with a sps (six point socket) using a losean (long or short extension as needed) and crank it cc (counter clockwise). If all else fails, hit it with a bfh (big friggin hammer).
the nut is inaccessable. ive got the strength to break it loose, but only if i was able to get to it. should i saw zaw and drill through the old stud and just nut and bolt it?
