Removing automatic shfter knob
Removing automatic shfter ****
I've got to remove daughters console (95) to find sticking problem. How do you remove the automatic shifter ****. I found the button top just pops up and off but need to remove the rest. I looked at it today when she dropped by, but had my driving contacts on so hard to see close up. Did not see or feel any set screw. Any help would be appreciated.
Ok I found the staple and got it out and all the center including spring. Thanks, BUT it will not pull off. Any tricks? I hate to pull too hard and break something. With the pin out, should it twist off or just pull straight up?
