The rear windshield...
When I press the button to heat up my rear windshield if its got frost on it or just got steamed up the button turns on and works great but depending on how long it wants to work it turns off by itself and when i want to turn it back on it won't do so unless i wait approximately 5-10 minutes, what might be causing this problem? a old fuse?
Mine will not remove the foggy steam from the glass but it takes out the ice really good. The controller for the defrost will heat up to a certain point (it knows this by the amount of current the heating elements draw) then hold for a few and then shut off and start a recycle timer. You have to wait till the elements cool before starting them back up. This is to prevent shattering the glass or burning up the elements. Your car is working normal.
Massey
Massey
Do you have a pic of this ground connection? My defrost light comes on but instantly turns off when i let go of the button, im assuming bad connection somewhere and its just defaulting out to save the window.
