Rear sway bar on my 97 v6 camaro
Old Feb 24, 2012 | 04:28 PM
Rocketray's Avatar
Default Rear sway bar on my 97 v6 camaro
When i purchased the car their wasn't nothing holding the sway bar up.its doesn't scrap the ground but i would like to but it back. I was told to get a linking kit but local stores didn't carry it...what size bolt does this require or do i have to actually by the link bushing kit
Old Feb 24, 2012 | 08:11 PM
libertyforall1776's Avatar
My '02 RS stock was 28mm front, 15mm rear, yours is probably the same...
Personally, I would be looking to upgrade your sways to at least 32/19 SS sways...
Old Feb 25, 2012 | 09:14 AM
Upgrade would be nice but he needs to get this fixed ASAP. On cars designed to have a sway bar a broken link is considered a safety item. Camaros are notoriously loose in the back end, one without a sway bar would be much worst (have one side hooked up does nothting). The rear V6 rear links are VERY common items you need to go to a different parts store. Heck I think on the V6s the front and rear links are the same and I think the links are used 1982-2002 in the rear. You do not what to just try to bolt it up because you are missing some very important parts. The rubber bushings and the spacer/washers that goes between them is very important to how it works. You should be able to find the link for 10-15 bucks. On Ebay you can buy all the bushing and hardware for the rear sway for about $30.
Note if you have never driven your Camaro with a working rear sway bar you are in for a treat. It will handle 10 times better on a hard turn once this is repaired.
Old Feb 25, 2012 | 09:48 AM
look around your local wrecking yards and see if they have any camaro parts. just looked for my old ones and could not find easily. ill be working in the shop today ill look around again today when out there.
Old Feb 25, 2012 | 10:04 AM
here ya go like 8 bucks youll need two. Search the RMS Automotive Products Database
ATM
Jul 4, 2013 09:52 AM
wayne242
Oct 17, 2012 12:45 AM
tlittle
Sep 22, 2012 09:32 AM
Anthony k
Jul 26, 2012 09:37 AM
aussiesmg
Dec 22, 2008 05:29 PM
