rear end and ABS question
I don't see why it wouldn't work. If both are 10 bolts, all that would mean is that the one with TC wouldn't have functioning TC since the car isn't equipped with it. But the "normal" functionality of the rearends would otherwise work the same.
The TC rear-end doesn't have the correct speed sensor mount because the TC cars rely on individua wheel speed sensors instead of one sensor for both rear wheels. Technically it will bolt up, but it's not the "right" rear-end for the car.
I drove a 96 or 97 T/A with traction control.. But for the condition it was in they were asking too much... so i got an eclipse.. woo... that turned out great, no?
idk if this may help you: http://www.chevyhiperformance.com/te...all/index.html
