Read my spark plugs
They look normal to me. Book says they should be light tan or light gray, which yours are. Check gap and if possible see what color the spark is when it fires. Bright Blue/Blue would indicate good. Yellow/Orange would indicate bad wire or coil. Do so with either a new plug, or an inline spark tester (this being the safer option).
Real Good
14
The Best
15
Best
16
Best
17
Best
18
Good
19
Good
20
Good
21
Kinda Hot
But OK
22
Hot or Lean
But OK (?)
23
Hot or Lean
But OK (?)
24
Hot or Lean
But OK (?)
25
Too Hot or Lean
Pre-Ignition Range
26
Too Hot or Lean
Pre-Ignition Range
27
Too Hot or Lean
Pre-Ignition Range
28
Too Hot or Lean
Pre-Ignition Range
Real Good
14
The Best
15
Best
16
Best
17
Best
18
Good
19
Good
20
Good
21
Kinda Hot
But OK
22
Hot or Lean
But OK (?)
23
Hot or Lean
But OK (?)
24
Hot or Lean
But OK (?)
25
Too Hot or Lean
Pre-Ignition Range
26
Too Hot or Lean
Pre-Ignition Range
27
Too Hot or Lean
Pre-Ignition Range
28
Too Hot or Lean
Pre-Ignition Range
yup just how mine looked the best ,when we did the headers pulled them ,could be the wires,it says you did headers did you get 90 degree wires ,did you change the wires ,I had to replace mine couse the old manifolds are in there own way on mine ,not sure about your v6 though
