random tick from passenger side
Old Aug 13, 2012 | 12:04 AM
auto's Avatar
Default random tick from passenger side
starting the other day ive been getting a random shake from the engine that stumbles but doesnt stumble when i get on the gas, i had the hood open just now and whether hot or cold i hear a random tick and with each tick the engine stumbles. i turned off the lights and i dont see any archs from the spark plug wires, when i listen to the tick it sounds like its coming from an injector plug or from the egr plug. it definitely sounds electrical, not like a injector tick, or belt tick. what could it be? and has anyone experienced this?
Old Aug 13, 2012 | 12:39 AM
plug wire, injector sticking, exhaust leak, lifter weak or sticking, valve spring bind, thats all i can think of
Old Aug 13, 2012 | 12:48 AM
auto's Avatar
its so strange and random, the tick doesnt sound like internal engine tick or knock, it sounds like when a wire is crossed
aside from the spark plug wire, can any of the smaller electrical wires cause a stumble that bad if they are making contact?
Old Aug 13, 2012 | 01:01 AM
there all low voltage, if you have a strong heart run your hand along the wires when its doing it, lol, so its a snapping noise
Old Aug 13, 2012 | 01:17 AM
auto's Avatar
I got shocked the other week but thanks, its somewhat snapping like or when you plug an outlet in the wall and you hear that little arch sound, and as soon as it makes the sound the same time the engine stumbles, how can i test coil packs? I never changed any, and am at 111k now. could be?
Old Aug 13, 2012 | 06:49 AM
jkeaton's Avatar
Sounds like a sparkk plug wire to me. Spark is jumping to ground somewhere along the way. Have you actually pulled them off and checked them?
Old Aug 13, 2012 | 10:42 AM
^^^ agree if your getting shocked by your wires they need to be changed. would be a good start. plugs and wires.
Old Aug 13, 2012 | 12:54 PM
auto's Avatar
is there a way to check it other than visually? like with a volt meter or something?
AmericanMuscle1989
Oct 17, 2013 07:51 PM
DMateo
Mar 20, 2009 11:51 PM
tirocz
82-92 V8 Tech
Mar 25, 2008 05:38 AM
Andrew*B
Oct 11, 2007 11:54 AM
b4cmoose
Jun 6, 2006 07:31 PM
