rail/injector removal
searched, no luck. anyone has a step by step? I looked on the car i see 4 nuts holding the rail but to disconnect the line on the driver side im having trouble with, any special tool needed?
Usually it is just a matter of unbolting the fuel rail from the manifold, disconnecting the fuel lines from the rail. and lift the rail and injectors out of the holes. They are only set in with friction from the O-rings. Make sure you use a little WD40 or other light oil on the O-rings when you put them back into the manifold.
Massey
Massey
Are your fuel lines going to bind somewhere, or are you changing fuel rails? On fuel rails/injectors that I've removed before, I've always just popped them up and out and left the fuel line connected. Also, don't forget to relieve the fuel pressure at the schrader valve first so you don't flood the cylinders with gas.
with ls1 and the tight space your best pulling the whole rail, literally undo the 4 bolts and lift the rail off
(check out ls1howto ls6 monifold swap and follow injector removal bit)
when your rail with injectors is out just leave it connected to fuel line but pull the clips off all injectors (watch as they spring off) and remove the injectors, make sure you get the O rings though as they are really tight injector to rail, and as the others said, to install put some wd40 or something on to slip them back in
Take it car is still running bad???
