radio headunit help
#21
cut the hatch it will get you the same access to the inside of the tank in an eight of the time
https://camaroforums.com/forum/showthread.php?t=54911
as for the suspension all you need to do is get the car in the air jack up the rear unbolt the shocks and let the rear down the spring will just fall out replace and bolt back up all in all replacing the springs and shocks should take no longer that 30 min
#22
Sounds good, I'll check in to it. I may PM you when I get ready. Man did we highjack Janks thread? I hope he saw the posts I made on the factory stereo's I have. I got them with a lot of parts I bought from a guy that switched from camaros to vettes as a "hobby" you should see this guys place! 3 different shop buildings about 40,000 square feet total and a parts "shed" that is about 1500 square feet. Retired civil service from Tinker AFB. Told me if he found anything else he'd let me know. So Jank, if your still there, I've probably got a stereo you can use.
monolithmonolith
06-27-2008 11:26 PM
