Rack & Pinion
Old 09-20-2011 | 09:57 PM
Default Rack & Pinion
I need a Rack for my 93 Z. Its shot. My local junk yard has one from a 2000 SS (this is the close ratio one) with under 50K on it. They want $150 and $45 for the U-joint that would replace my rag joint. Anyone know of a better place to get a rack? I want the close ratio Rack. These where installed on Y87 cars and I think all LS1 cars. A reman rack would be great if I can find one resonably priced.
Old 09-20-2011 | 10:13 PM
They want a lot for a used unit don't they. A reman AC Delco rack (minus the u-joint) for a 2000 SS is $202 at rockauto.com. An AC Delco replacement for your year is $143 with either a 2.75 or 2.25 turns model available. How many turns is the 2000 lock to lock?
Old 09-20-2011 | 11:01 PM
libertyforall1776's Avatar
I'm curious, what are the indications that your rack is shot?
Can you explain what is meant by a "close rack"? I thought there were two versions, one on the base V6 with a basic turn ratio, and a tighter turn ratio on the V8s & Y87s. What am I missing?
Old 09-20-2011 | 11:20 PM
There is about 1 inch of play in the steering wheel that track down to the rack and pinion. Close ratio rack is the shorter rack or smaller ratio.
Do you have a link for the AC delco? I think the 2.25 is the rack I want. The local yard is Fbodys in Philly, its a big one, I can not believe they are asking more then a reman.
Old 09-20-2011 | 11:25 PM
Old 09-20-2011 | 11:32 PM
Question
Are you implying all Z28s did not receive the close ratio racks then? I thought they did?
Old 09-21-2011 | 06:30 AM
I had a link to a post that listed the cars that did and did not have it. The thing I remember was that all LS1 Z had it. I will see if I can find it.
Old 09-21-2011 | 06:36 AM
LOL, I should have looked harder even autozone has remans for $142 with the 2.25 ratio. I'll bet the wife can find a $20 off coupon,,,
Old 09-21-2011 | 11:35 AM
Lightbulb
Hey Gorn, check out what these folks say about remans, buyer beware... I've read the GM remans are good, though.
http://ls1tech.com/forums/suspension...k-options.html
Also, check this link:
http://shop.rackdoctor.net/CAMARO_c40.htm
Reportedly the ratios are: V6 one is 16.9:1, the V8 14.4:1.
Anyone have the factory code handy for the "close ratio" rack?
Old 09-21-2011 | 06:11 PM
Here is the thread I was thinking about. There is a some miss information in there but they get it straight in the end. Note how old the thread is. I read it 3 years ago.
There are only two designs V8 and V6 its the joint that was changed for the LS1.
High ratio steering racks - FirebirdV6.com/CamaroV6.com Message Board
jlbonnie2000
11-18-2012 09:11 PM
husker_camaro95
07-02-2010 09:33 AM
chrisgray86
12-29-2009 11:35 PM
jcZ28
09-18-2008 05:58 PM
dhill
05-08-2008 10:55 AM
