quick question
Old Sep 23, 2007 | 01:22 PM
NasteeZ's Avatar
Default quick question
how long do u think it will take to swap a rearend?
Old Sep 23, 2007 | 02:06 PM
Chappie99's Avatar
Default RE: quick question
If you have a lift, half day. If not a full day. Granted that your are putting the same exact rearend in. Meaning if you have a 99, you are putting in a rearend from a 99. I swaped mine a few months ago. I am experienced at these things. Buy I put the rearend from a 95 Z28 into my 99 Coupe. The brakes were totally differnt, so after swaping one set of lines from one to the other, and realizing that the ABS were differnt (speed sensors) it took a little while. Make sure you have a 18 mm 21mm which are some of the larger size tools you need. If you have a 18mm gear wrench for the control arms, it will be very helpful. Depending on your location if you are in the "rust belt" be sure to have plenty of penatrating oil. Impact tools will also be a huge help,HUGE.
blackbeauty1995
Mar 18, 2014 06:08 PM
gmman200
Mar 1, 2009 11:36 PM
sk8erdude36
Dec 12, 2008 06:48 AM
Celticsfan
Oct 9, 2006 02:01 AM
