Question About Differential Oil.
ive always been told you should change it every 50k miles. also you should use conventional 80-90 1.75qt. does your car have an lsd rear? if so you need to use lsd additive. to drain unbolt the bolts starting at the bottom and moving up equally on either side with a drain pan underneath, get your self a new gasket too. to fill there is a plug somewhere towards the top of the cover, this is also the full line. fill the diff up to the bottom of the hole. you may also want to get a fluid pump (kinda looks like a shampoo pump with a hose on the nozzle)
it might be, i never did it on either of my camaros. PM chaotic94 hell know for sure.
