A question?
Old May 7, 2013 | 07:17 PM
Sicilian's Avatar
Question A question?
The cooling tube that goes into the lower manifold and has a pipe the directs hoses to the throttle bodie, Can I bypass the throttle cooling and run it straight?
Also: The Oxygen Sensor's how do I know which one is which?
Can I get twon of these: http://shop.advanceautoparts.com/web...465%7CL3*16466
Also, Where can I find the gasket for the oil filter adapter?
Old May 7, 2013 | 09:00 PM
not sure how the 3.4 like the bosch 02s the lt1 does not like em. 93 is a one wire 02. rockauto has acdelco # AFS21 for 15 bucks and i do believe you can get a discount using a number on the site somewhere. here it is 5% Discount Code: A12AF4D60D85
Expires: 05/08/2013
RockAuto Parts Catalog
Old May 7, 2013 | 09:06 PM
Better move fast, the rockauto 5% discount expires tomorrow. Here's the code: A12AF4D60D85
Old May 9, 2013 | 01:46 PM
Sicilian's Avatar
Ouch I missed that! Sorry got caught up in other issues....
Old May 9, 2013 | 02:05 PM
See if it still works. A Rockauto rep is in here periodically posting different promos, and additional discount codes.
Old May 9, 2013 | 06:36 PM
Sicilian's Avatar
Ok, but can you tell what the name of that piece is I asked about?
Old May 9, 2013 | 07:10 PM
slick's camaro's Avatar
And yes you can bypass the throttle coolant pipe. It was designed for colder environment s where as the plate would freeze and stick
Old May 10, 2013 | 02:42 PM
Sicilian's Avatar
Sweet thanks, one more question? I made the mistake of painting my upper intake manifold with rust-olem and it shows that it can only handle like 200*F or sumshyt, will this paint work or do i need to clean it off and use hightemp paint?
Old May 10, 2013 | 05:24 PM
Shouldn't get that hot, but fail safe use high temp
Old May 10, 2013 | 05:29 PM
Sicilian's Avatar
Thats what i thought, Now I have to find a way remove all this paint, can i use a thinner or something?
