Procedure for replacing a Crankshaft Position Sensor (94 Z28 6spd)
Old Jun 7, 2008 | 03:59 PM
rwing7486's Avatar
Default Procedure for replacing a Crankshaft Position Sensor (94 Z28 6spd)
just looking for the easisest way to go about replacing my crankshaft posotion sensor and the steps i will need to take. also some tips and tricks would be apreciated
Old Jun 7, 2008 | 10:24 PM
Default RE: Procedure for replacing a Crankshaft Position Sensor (94 Z28 6spd)
Replacing the Crank position sensor on an LT1 is an impossible task, mainly because the engine does not use one. Clocking signals to the PCM are provided by the Optispark distributor via the Low and High reference signals.
Old Jun 8, 2008 | 01:53 AM
rwing7486's Avatar
so if i get fail codes lo and hie res i should replace the opti spark?? even though my spark plugs are filled with soot saying the engine is running rich???
Old Jun 8, 2008 | 09:22 PM
Just because the plugs are fouled it does not mean that the engine is running rich, There are many reasons for plug fouling beside an over rich mixture. Plugs can foul due weak spark, bad spark timing, improper heat range, improper reach, improper gap, etc....
Another cause of fouling could be that excessive fuel is being delivered, which could be due to excessive fuel pressure, bad injectors, bad sensors, especially the O2 sensors.
Being that the Opti is throwing codes and being that you recently replaced it, it would be fair to say that the Opti is still good and there may be a wiring problem. Check all wiring and connectors between the Opti and PCM, PCM to coil control module, and from coil module to coil. Also make sure all high tension wiring is OK, coil to Opti, and Opti to spark plugs.
jml2002
Jun 11, 2013 09:52 PM
Growler75
Oct 19, 2011 02:55 PM
jackrabbit66
Jun 12, 2011 10:08 PM
thetal1
Feb 13, 2010 03:05 PM
crw2008
Jul 21, 2008 08:23 AM
