problem seperating the tranny from the engine
Old Sep 30, 2008 | 05:51 PM
94z's Avatar
94z
Default problem seperating the tranny from the engine
Alright guys i managed to get the engine out of the car with the tranny attached. Now i have run into a problem seperating them. Do i have to push the clutch in or something? I have all of the bolts removed and it will come off of the engine about a inch or so but wont come all the way off, i thought that they would just come apart after removing the bolts.
Old Sep 30, 2008 | 05:57 PM
02StanGT's Avatar
Default RE: problem seperating the tranny from the engine
Pull harder?
Old Sep 30, 2008 | 06:00 PM
94z's Avatar
94z
That might be it but I wanted to make sure I didnt need to do anything wit hthe clutch like compressing it. The engine is still on the engine hoist and my dad and I spent the last hour playing tug o war with it. Maybe a pry bar?
Old Sep 30, 2008 | 06:05 PM
02StanGT's Avatar
The clutch shouldn't need to be depressed. The input shaft is probably being stubborn and stuck in there. Can you look in there to see if anything is hung up for some reason?
Old Sep 30, 2008 | 08:10 PM
94z's Avatar
94z
I can see down inside of it, doesnt look like there is anything obviouseholding it in place but then again I wouldnt really know what to look for if there was something there. Ill try cranking on it again tomarrow and see how it goes.
Old Sep 30, 2008 | 08:24 PM
02StanGT's Avatar
Good luck.
Old Oct 1, 2008 | 12:42 AM
95slvrZ28's Avatar
My only advice: Make sure you're separating it equally on all sides, if you start to pivot the transmission and not the motor you'll get torque on the bolts and you won't be able to slide it, so go straight back. If you're already doing that...pull harder.
Old Oct 1, 2008 | 03:50 PM
cbr600rx7's Avatar
Big hammer and a cheater bar
Old Oct 2, 2008 | 07:52 PM
deltav's Avatar
I hope you released the clutch fork. If not, your situation will happen; all bolts off but will only seperate about an inch or so while pulling straight back. If you haven't, and it won't come loose on it's own, you need to pull down on the clutch fork. There's an indenture on the bottom of the clutch fork that you need to push in, then down to get it unhooked from the throwout bearing. This is assuming you unbolted your slave cylinder along with the spacer, or else you won't even see the clutch fork.
Old Oct 3, 2008 | 12:45 AM
importmd's Avatar
unbolt the bell housing from the trans, pull back the trans, look inside at the clutch fork, 13mm box end wrench, thats whats holding you back.
