problem with my 96 z28 lt1
thats from oil and water mixing, the water is usually from moisture when its in the valve cover. Do you have a breather from one cover and not the other?? I'd only worry a lot if that peanut butter sludge was in my coolant! lol
I'd clean as much out as you can and give the car a good service, oil change and filter and then see how it goes. How often do you change the oil??
white smoke coming from your exhaust; water intrusion detected in your oil.
I believe you know what's going on.
It's not a big deal, it's just going to take time (and money depending if you want to take advantage of the down time) as long as you have tools.
Now's a good time to decide if you want to freshen the top end, upgrade the cam, since you are going to take off the heads. Maybe also add some headers.
