Power Windows. HELP!!!
Old Jun 25, 2009 | 08:07 AM
95camaro95's Avatar
Default Power Windows. HELP!!!
OK so I have a/c but I like to roll down the windows ever once in a while. But my motors (both sides) are GONE. My driver side window it partial cracked and lately it's been raining in FL. I've been trying to pull on the dang thing to fix the crack but I can't. Anyone have an idea (besides buying a motor) on how I can fix this? I said screw it, I'll use a/c. It's TOO hot here anyways to roll down the windows. HELP ME!
Old Jun 25, 2009 | 08:54 AM
check the switch. check the connection at the switch also check your fuses. ussually the motor will work a little before it overheats and stops. did they both quit at the same time?
Old Jun 25, 2009 | 09:08 AM
nyamped88's Avatar
The 95 I'm looking at also has a driver's window issue. The motor grinds but the window doesn't move. I'm not thinking it's going to be an easy fix or a cheap one either..
Old Jun 25, 2009 | 03:51 PM
the motor change really isnt all that bad. easier than changing plug wires. go here and read it over.
http://shbox.com/page/windowmotor.html
Old Jun 26, 2009 | 07:51 AM
95camaro95's Avatar
Well I can change the window motors out no problem...I just don't want to buy them...i just want to know how to roll it up...oh and the passenger side windows was already out when i got the car...the driver side just went out..and yes i did check all the connection and everything.
Old Jun 28, 2009 | 01:02 PM
sig556's Avatar
I know you said you didn't want to buy new motors.
Possibly buy some used ones from a junk yard? Might do the trick until you can buy new ones.
Old Jun 28, 2009 | 01:44 PM
osduck5's Avatar
You could probably pull the inside door panel and remove the motor then push the window up. Then put the motor back in but that is alot of work to do if you are not going to replace the motor at the same time. I don't know of any other way to get the window up since it is gear driven by the motor.
Old Jun 30, 2009 | 12:59 PM
95camaro95's Avatar
alright this is really weird now...i was messing around a few days ago with the switches and the window started to roll down, then i quick pushed the up button and it rolled up...still a little crack but better then before...i also started to hear like a weird noise coming from the dash...almost like a clicking...anyone have an idea what this could be? i checked the fuses and their all fine...i think it might be the switch it self...and if it is, is there anyway to by pass the switch and roll it up completely?
Old Jun 30, 2009 | 01:10 PM
the noise could be the express down modual. to hot wire the up wire on the switch in my book for a 93 shows the brown wire as hot and the grey wire as up for the driver side window. dont let the day end without voting for your fav rotm car. go to the rotm page and vote.
Old Jun 30, 2009 | 02:23 PM
95camaro95's Avatar
ok so the brown and the grey wire...got it...but how would i HOT wire it?
