Power window question
Old Sep 1, 2010 | 12:42 PM
ACEDEAN's Avatar
Default Power window question
Not the common question you all used too!!!
95 firehawk #298
have tried 2 different motors on drivers side ( this is my 8th f-body i getting good at that)
when i roll the window "all" the way up or down the motor will not work again until i bang the door right by the motor.
both motors was dorman, which i have never had a problem in the past with
Thanks for any help
Old Sep 1, 2010 | 01:52 PM
this help?
Size:  46.8 KBName:  P7090002_1.jpg
Size:  66.6 KBName:  P7090004.jpg
Size:  54.2 KBName:  P7090006.jpg
Old Sep 6, 2010 | 10:15 AM
ACEDEAN's Avatar
where do you find express window down modules? maybe it is that
Old Sep 6, 2010 | 03:46 PM
Carl Dan's Avatar
you should check your power window circuit breakers as listed in the tech doc's that craby listed. if they are good take the door off and check the voltage on your power window switches and see if they have any corrosion or if they are loose or have broken terminals. if all that is good then check the harness that plugs into the motor and do the same, check for voltage, corrosion, broken loose terminals. the location of the express down in the tech doc says on dash mat above floor tunnel.
cornmuffin
Jul 24, 2014 10:22 AM
Eagle564
Aug 15, 2011 06:13 PM
Graphite07
Apr 4, 2010 04:42 PM
blink18236dude
Jun 25, 2008 07:23 PM
fire ball
Jul 17, 2006 04:15 PM
