Passenger Side Power Window; Not working.
Hey guys,
The guy I bought the Camaro from told me that a fuse is out, and thats why the window doesnt roll down. I replaced the fuse, and it still does not work. I'm thinking motor, but it could be wiring... Is this generation notorious for having this problem? The drivers side window rolls down, but it takes its time.. Thanks!
Sounds like motor and possibly the one on the drivers side soon! I had to replace one a few weeks back on a 96 but considering I had to drill out the rivets, I think it was the original window motor.
^^^ agree the motor is probly a gonner and the other going. get your test light out and check for power at the switch. it should pull out fairly easily. sometimes the wiring harness at the door hinge will get jammed or kinked and the wires part. was the fuse burnt out. if so before u tear into the motor change check for juice at the switch. heres a write up for ya on changing window motor.
http://shbox.com/page/windowmotor.html
first check to see if you are getting power to the switch. if you are, the it is probably the motor. If it is the motor, you might as well replace the drivers side motor too because that one is about to go out
Comanro
07-12-2014 05:13 PM
