Parking brake wtf
This was awhile ago, I went to pull the brake, and it came all the way up, with no pressure on it, and felt like I broke it. I put it back down, pulled it back up, and it held as it normally does.
Wtf? It hasnt had a problem since. Just wondering what the hell happened there |
RE: Parking brake wtf
happened to me once also. thought the cable snapped but it didnt and it was ok after that.
your parking break can be adjusted from under the car, sometimes it will do that if you pull it too hard and fast
When I set the parking brake, and then take my foot off the brake, the car still rolls back a little and then stops. Is this normal?
ORIGINAL: DMateo When I set the parking brake, and then take my foot off the brake, the car still rolls back a little and then stops. Is this normal? |
Ok thanks yeah I'll get it checked out probably
