Output shaft.
Old 11-30-2012, 07:58 PM
JakeYeah's Avatar
Default Output shaft.
'Sup guys. Heres what i got for you. Every time I floor it in my car, theres a loud bang. Under the common issues section for my transmission, (a4), It says that a loud bang is associated with a snapped output shaft. My question is, what would i need to do in order to remove and replace it? (i.e. where is it located, what are you gonna have to take apart to reach the part, any useful hints, etc.) Appreciate any help given.
Old 11-30-2012, 08:38 PM
If your output shaft was snapped, the car wouldn't move. A more common cause of what you're experiencing is a torn transmission mount, which lets the tail of the trans lift under torque, and bang the tunnel.
MKCoconuts's Avatar
You have the tear the trans apart to get to it. Best let a shop do it. Other causes though would be the trans mount being broken.
I was beat to it...
Old 11-30-2012, 11:07 PM
^^^ yep its a 15 dollar trans mount, easy fix takes like 15 minutes.
Old 11-30-2012, 11:10 PM
somebody needs to take some picutures when they do it and make a how to thread. next time i change the trans ill have to.
Old 11-30-2012, 11:13 PM
That's why it's not in the how-to section, it's too easy to have to explain!
And while someone's at it, might as well make a how-to on how to insert the ignition key and start the engine!
Old 11-30-2012, 11:16 PM
i could do one using the change the trans how to pictures,,, maybe,,,
Old 11-30-2012, 11:18 PM
JakeYeah's Avatar
Cool thats a load off my shoulders. Would the mount be located on the tail of the tranny or the head?
Old 11-30-2012, 11:20 PM
lmao,, the tail
Old 11-30-2012, 11:21 PM
Fyi, it's your rearend that's lifting your tail.
Quick Reply: Output shaft.
