opti spark going bad
Old 05-16-2010, 10:36 PM
BMCossey97Z28's Avatar
Default opti spark going bad
well i have a newish opti in my 97 z28 and am cerious if those things just fail ad thats all she worte or can they fail work fail work ect. and could that be the cause of my car shutting off during driving, then starting back up hours later?
Old 05-17-2010, 07:26 PM
ignition module or coil will do that. i had a ignition module go and it drove me nuts. drive it a couple miles down the road and it would die. id go get someone to tow it home and when we got ready to tow it would start right up. i now carry an extra module in the car. yes a opti going can do weird things and u can get a bad new one especially if its not a gm performance opti. the cheap ones are not reliable.
Old 05-17-2010, 09:10 PM
well i think i figured it out, i took the opti apart and it looked like it had been sitting out in a hurricane. is there any possible way that liquid could get into the vapor lines that go into the opti and the dist cap? if not what would make my water pump seep out that much antifreeze
Old 05-17-2010, 09:27 PM
leaky water pump or coolant hose. many new opti s have had short lives because the water pump was not replaced when the opti was.
Old 05-17-2010, 09:31 PM
i use high temp rvt on the o ring for the cap to help seal it up. i also use electrical grease on all the plug wires and the wire harness inlet. the coolant can set on the inlet and drip in through the seal.
bd92rs
09-26-2011 11:17 AM
camarorz28
07-25-2008 10:56 AM
nash211
01-15-2007 05:42 PM
ufnwish
10-08-2006 06:38 PM
kwest
06-13-2006 09:03 PM
Quick Reply: opti spark going bad
