opti problem??
Old Apr 27, 2008 | 03:10 PM
BlKnt18's Avatar
Default opti problem??
So I just bought a 94 z28 camaro. It's red, t tops, 6 speed with 164000 miles. It runs pretty good but has a couple things that need some work. The front suspension on the passengers side squeaks but the main problem is this misfire. It runs great on idle and rev and usually when just cruising at 60 but sometime at low rpm while cruising it flutters. It is really bad sometime on an accel. If I really get on it, it will miss and flutter bad sometimes. If I'm accelerating slower its usually ok. What do you think?? Thanks. Oh ya and it has new plugs and a k&n intake and cat back flowmaster(all previous owner, small dealership where I bought it did the exhaust so it is brand new)
Old Apr 28, 2008 | 09:11 AM
kaoss_11's Avatar
Default RE: opti problem??
sounds like you already know the answer
Old Apr 28, 2008 | 10:07 AM
Spartan66's Avatar
sounds like the opti issues im experiencing. no SES light?
Old Apr 28, 2008 | 12:13 PM
BlKnt18's Avatar
no light. Runs good most of the time usually just bad at wide open
Old Apr 28, 2008 | 12:40 PM
Spartan66's Avatar
does it feel like its being slowed down at all? not asquick or torqueyas usual?
Old Apr 28, 2008 | 04:08 PM
kaoss_11's Avatar
I had the same symptoms 2 weeks ago I changed the opti and coil and now she runs like a champ
Old Apr 28, 2008 | 06:15 PM
95slvrZ28's Avatar
Could be the opti, but it could also be a clogged cat if it's only doing it in high RPMs.
Old Apr 28, 2008 | 06:17 PM
BlKnt18's Avatar
Nope cat is gutted from previous owner. Ya it feels slow but misses a crap ton. Also does it a little at low rpm when I try to accell without down shifting.
Old Jun 12, 2008 | 08:38 PM
93LT1MaroBoy93LT1's Avatar
Not trying to hijack the post, but i have a 93 lt1 and i have some what the same problem when it heats up, it seem slike it looses power. Also it will run great then fall flat on its face and chug around 300-500 rpms Almost as if its running out of gas car will not accelerate at all and sometimes die and not restart, Cat will get red hot and start smoking. Is this a spark problem or a fuel problem?
noz
May 28, 2010 08:58 PM
sbcman25
Jan 29, 2010 02:01 PM
sprintcar17m
Jan 17, 2010 07:43 PM
Unit94Z28
Jul 9, 2009 09:19 PM
ryan88z
Jul 5, 2009 06:35 PM
