One day...after a start...
http://www.youtube.com/watch?v=2YbCLMIy2ro
http://www.youtube.com/watch?v=0dbhsVhE9N4
Whats that sound is it an exhaust leak? It stoped after about 5 seconds of driving...well it was still there but you can barely hear it.
That is lifter noise. What did you have done to the car? Lifter noise can be caused by mis-adjustment (non likely on a 3800) , low oil pressure, Dirt in the oil, failing lifter "pump" or a failing cam/roller.
Is there any tutorials out there on how to remove the valve cover? I don't want to mess it up
Driver's side
remove coil pack, remove brackets that are in the way, remove valve cover.
Pass side.
Remove alternator brackets, remove engine lift bracket in the back (cuss alot over this) remove valve cover.
Massey
Pass side.
Massey
