ok...
Old May 29, 2008 | 05:46 AM
meteoralp45's Avatar
Default ok...
since no body could help me on here, im assuming people dont know, but i finally found the parts that you need to replace when you replace the water pump, so tomorrow, im doing it all over again and replacing the things i didnt, and when im doing it im gonna take pictures and post up in the lt1 section how to change a water pump
Old May 29, 2008 | 06:48 AM
bluovlh8er's Avatar
Default RE: ok...
have fun with that, its not as easy as it looks
Old May 29, 2008 | 08:36 AM
kaoss_11's Avatar
Default RE: ok...
Its very simple to change and not hard at all. From my own personal experience I like to take the radiator out. It makes things move a lot faster and easier
Old May 29, 2008 | 01:19 PM
importmd's Avatar
Default RE: ok...
it takes longer to drain the radiator than it does to take out the water pump.
Old May 29, 2008 | 06:19 PM
Default RE: ok...
no its not changing the water pump thats hard, theres two o-rings in there that u should replace and the bearing on the driveshaft, that i had no clue about, and no body on here could tell me what those o rings were called or where i could buy them or how to replace them, cause i replaced the water pump and now its leaking oil from those o rings
Old May 30, 2008 | 09:45 AM
importmd's Avatar
Default RE: ok...
you mean the main seal around the crank shaft, and the seals for the water pump drive and opti? go to the auto parts store and ask for a timing cover gasket kit. should come with timing cover gasket(you cant do this with out droping the oil pan) water pump gaskets, and the three seals for the front of the timing cover ie. crank, water pump shaft, and opti.
Old May 30, 2008 | 12:52 PM
LT1RUNNER's Avatar
Default RE: ok...
ORIGINAL: importmd
Bingo!! Now the real work begins. I have that same problem but I don't feel like tearing down the entire front of my engine so I bought a rubber mat. HA!
Old May 30, 2008 | 11:46 PM
Default RE: ok...
ORIGINAL: importmd
lol yeah i know, i already did that, but i wish someone would have told me that like a week ago though, i had to figure out on my own. but yeah, i did it today, actually had to get a whole new water pump, one of the fittings on the upper hose that runs into the pump had completely came out with the hose still on it tight, the whole metal fitting came right out, so i got a new one, used that kit, cept the opti, didnt touch that. and yeah, shes runnin good now..but...i lied, i couldnt get a hold of a camera so im just gonna say screw it on the post on how to do it, but if anyone ask, i know now!
