An oil question
Old Feb 24, 2012 | 05:29 PM
Javs_is_fat's Avatar
Default An oil question
I have a '94 Z28 Convertible and the top motor has leak, it's drained of fluid. I read that it needs a 10 weight SAE oil, would that mean 10w 30 motor oil would work in the pump? My dad thinks they mean just a straight 10 weight oil, I don't think they even make that. Thanks guys!
Old Feb 24, 2012 | 06:16 PM
can you tell if it had transmission fluid in it before? is it red? if not i would think it would be hydraulic fluid. could be 10w motor oil if its made and if it is you dont want to mix it with trans fluid. call your local gm shop and ask em what is used.
Old Feb 24, 2012 | 06:46 PM
The manual calls for tranny fluid but that was incorrect, GM issued a notice saying to use 10 weight SAE oil. The tranny fluid has additives that dry out the seqls on the o rings. The fluid in it before looked like oil, it def. wasn't red. But it all leaked out, the reservoir and pump were dry.
Old Feb 24, 2012 | 06:54 PM
BasicConcepts's Avatar
Technical User
i used hydraulic jack oil to top off my pump when i had a leak
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
