oil pressure gauge
Old Jul 1, 2007 | 11:56 PM
jtd_1's Avatar
Default oil pressure gauge
Has anyone replaced their oil pressure gauge in the instrument cluster on a 97 Z28?
I hooked up a mechanical gauge to my engine and my oil pressure is great from that but when hooked up normally my gauge reads really low, and at idle it drops down far enough to kick on the check gauges light. I have changed the sending unit and same result.
Thanks
Joe
Old Jul 2, 2007 | 06:22 AM
usarmyrangrs's Avatar
Default RE: oil pressure gauge
If the actual gauge is suspected to be faulty, I'd recommend installing an aftermarket gauge. The only way to correct a faulty gauge on our cars is to replace the entire instrument panel. Not a hard task, just more expensive than it ought to be.
93bumblebeeCAMARO
Feb 15, 2012 05:43 PM
josh95camaro
Oct 9, 2009 10:15 AM
red99camaro
Oct 21, 2007 12:26 PM
finally71Z28
Sep 18, 2007 10:36 AM
jtd_1
Jul 1, 2007 08:17 PM
