oil changing problems
Old Jan 9, 2009 | 02:34 PM
305pride's Avatar
Default oil changing problems
so i went to firestone the other day to get my filter and oil changed and they told me they couldnt cos my oil pan plug was broken or something. they said they tried pulling it out and it got stuck or something and if they took it out it might not go back in. so i think they said i have to buy a whole new oil pan or what ever. what do u guys think i should do? i think i might have been having oil leaks for a while.
Old Jan 9, 2009 | 04:48 PM
Default RE: oil changing problems
Taske the silly plug out and replace it with an oversize one. Most parts stores carry them. The one in there now is probably cross threaded and hard to remove. The oversize one will cut a new set of threads as you screw it in.
Old Jan 9, 2009 | 05:02 PM
whammer3024's Avatar
ROTM Winner
^^^yup...i sell them at my store. any parts store around should have them
Old Jan 9, 2009 | 05:21 PM
305pride's Avatar
you sure? i just called and they told me to fix that hole or replace the pan. getting a bigger plug is what he meant by fixing the hole? and if i want to replace the pan where do i get it? i want to fix the problem as soon as i can.
Old Jan 9, 2009 | 05:27 PM
ROTM Winner
what are we working on? i'm leaving work now but i will get back on in the morning from work and see what i can find for ya
Old Jan 9, 2009 | 05:29 PM
305pride's Avatar
im not working on anything yet. i just wana fix my oil pan so i can change my oil already.
Old Jan 9, 2009 | 05:34 PM
305pride's Avatar
and i cant find v6 3.4l oil pans. do the 3.8l ones fit??
Old Jan 9, 2009 | 06:18 PM
NO, it won't fit! Sounds like you want to fix the problem by talking about it. We told you what to do, but apparently you don't like the solution. If you want to change the oil pan, it will be costly, not so much of for the pan, but for the labor. You can get a new pan at most parts stores or from a GM dealer.
Old Jan 9, 2009 | 06:31 PM
SpecterGT260's Avatar
Ninja Administrator
just go get the plug man..... it will be cheap and will take no time at all.
Old Jan 9, 2009 | 06:32 PM
305pride's Avatar
ok i'll do it. thanx guys.
