o2 elminator
RE: o2 elminator
The O2 eliminators, usually referred to as O2 sims,take the place of the downstream O2 sensors (after the cat). They are available from Summit, Jegs, and other vendors. You still need the upstream O2 sensors in order for the engine to run properly.
RE: o2 elminator
You can basically make one for a few bucks. The second O2 sensor typically is not important for AFR readings, its only purpose is to detect a difference in exhaust flow (which will be impeded, by a catalytic converter) between the first and second sensor. So, all you really have to do is move the sensor slightly out of the stream of exhaust from the pipe. Some people weld on properly threaded nuts, tubes, or the little spark plug defoulers.
RE: o2 elminator
wow why dont you let us know were you live mullet so i can kick your mullet dumb ***,go back to the ****ing crack house you *** and stop bringing up old post and talking **** before you get banned.[sm=icon_beat.gif]
