a nice wiring table
Old Nov 25, 2008 | 12:51 AM
93maroonz's Avatar
Default a nice wiring table
Item
Wire Color
Polarity
Wire Location
12 Volts
red
ignition harness
Starter
yellow
ignition harness
Ignition
pink
ignition harness
Accessory
orange
right of drivers kick
Data Bus
wht to wht/blk(resistor), wht to pur/wh(reference)
vats
ignition key cylinder
Lock Motor
gray
drivers door harness
keyless entry module
The keyless entry module is located in the passengers kick panel
Driver Unlock Motor
tan
Parking Lights
brown
drivers kick panel, harness heading to rear
Headlight
yellow
headlight switch
Left Front Door Trigger
gray
neg
behind left rear speaker
Trunk/Hatch Pin
tied in with door
Trunk/Hatch Release
black/white
low in the passengers kick
Tachometerwhite or red/black
white v-6 red/black v-8
Location is front of left cylinder head for V6 and at a 4 pin plug at the passenger side valve cover for the V8.
Speed Sense
green/white
232[/font]233
rear of instrument cluster
Brake Wire
lt. blue or yellow
at brake switch
Horn Trigger
black
black conn. st. column
wipers
green or grey
right Front Window (Up/Down)
lt. blue - tan
a
Left Front Window (Up/Down)
dk. blue - brown
a
drivers door motor
radio 12v
constant/orange
factory wiring harness in dash
radio ground
black
Radio Ignition
switched/yellow
Radio Illumination
grey
Left Front Speaker (+/-)
(+)tan(-)grey
Right Front Speaker (+/-)
(+)light green(-)dark green
Left Rear Speaker (+/-)
(+)brown(-)yellow
Right Rear Speaker (+/-)
(+)dark blue(-)light blue
dimmer
brown
antenna trigger
pink
heater blower
orange
ignition harness
power lock
light blue
see note 1
power unlock
dark blue
see note 1
dome light supervision
use door trigger
break light switch
light blue or yellow
switch above break pedal
anti theft
2 white 1 purple in orange sleve
vats
ignition switch
note 1
if vechicle DOES NOT have a FACTORY KEYLESS ENTRY, use the LIGHT BLUE for LOCK and the DARK BLUE for UNLOCK
the wires are in EITHER KICK PANEL. You MUST use the PASSENGER SWITCH as the MASTER SWITCH when testing.
For vechicles WITH FACTORY KEYLESS ENTRY use the RED\BLACK for LOCK and the ORANGE\BLACK for UNLOCK. Both wires
are located in the PASSENGER KICK PANEL at the FACTORY KEYLESS ENTRY MODULE.
if anyone has more to add feel free
Old Nov 25, 2008 | 12:58 AM
95slvrZ28's Avatar
Default RE: a nice wiring table
We really appriciate the effort, but not to steal your thunder or anything...
http://shbox.com/1/schematics_wiring.html
There are complete wiring diagrams with color and connector type listed there...[:@]
Old Nov 25, 2008 | 01:24 AM
93maroonz's Avatar
great i will take a look at that site as well then. I am going to install an alarm and have had a hard time finding a good wiring write up that covers everything. so I tried to put all the small ones togeather. but thanks for the info. the more help the better
Old Nov 25, 2008 | 01:31 AM
95slvrZ28's Avatar
Like I said before, thanks for the effort! Good luck on your project!
z28pete
Apr 7, 2010 10:34 PM
BigNic
Mar 27, 2008 04:10 PM
