Newbee
Old Nov 30, 2014 | 10:21 PM
cwilt's Avatar
Default Newbee
Hello camaro enthusiasts. i have been browsing this site for a while and have found it full of great information. i have a 94 camaro 3.4l with 275k. i have owned this car since new. i am a air force mechanic and have always worked on this vehicle my self (except for tire balancing and alignments). i am on my third clutch, and have installed a solid drive shaft. numerous suspension upgrades. not to mention towing a small boat with her. her time has come for a overhaul. she runs like a top but i have a coolant leak with NO visible leaks on the ground or elsewhere. she has also lost a lot of spunk. So, i am going to give her a top end overhaul. i am in no rush though, she's not my daily driver.
just introducing myself.
thanks chris.
Old Dec 1, 2014 | 08:38 AM
Camaroforlife's Avatar
Welcome Chris! Good luck D:
Old Dec 3, 2014 | 08:17 PM
CountTripula's Avatar
welcome to the site,
I have owned a 3.4l 5 speed and it was loads of fun but if thats the original motor with 275k on it i would either go crate or completely overhaul the whole motor,ie (valve job, new piston rings, ect ect) just my opinion
cause you will notice a major difference between a new motor and a motor that has 200k+ miles on it.
Just my opinion and good luck and any questions this site has been loads of help
Old Dec 8, 2014 | 08:25 AM
Everett#2390's Avatar
Welcome, Chris, and Thank you and your family for the service.
Congrats on the Camaro service., but I agree with Count, figure on a complete engine overhaul.
Doing just the top end, the short block will fail later.
You may have already, but get a Haynes manual for the Camaro to assist, unless you bought the Helms manuals from the order form in the Owner's Manual.
Old Dec 8, 2014 | 11:04 PM
J-Factor's Avatar
I 3rd the complete overhaul, do the whole thing and go another 275k.
Thanks for everything you do for us!
Old Dec 10, 2014 | 05:58 AM
i would do a compression test before removing heads, if compression shows good then would consider top end. look around you might get lucky and find a low miles 3.4 to play with. go here and download a factory service manual, click on 1994fb http://www.mediafire.com/?40mfgeoe4ctti give thanks to garydoug for these
old timer
Apr 6, 2010 10:08 AM
Dount
Oct 30, 2009 07:56 AM
foster
Nov 16, 2008 02:55 PM
1st thirdgen
Jun 15, 2008 03:52 PM
carmik
Jan 12, 2007 05:56 PM
