New Wheels!!!
Old Oct 8, 2008 | 05:30 PM
Mr. Wheel's Avatar
Default New Wheels!!!
Found these online and cheap! I will post pics when I get them on..... Waahoooo! 18*10.5 rears and 18*8.5 fronts. Any suggestions on tire size?
Old Oct 8, 2008 | 05:34 PM
importmd's Avatar
Default RE: New Wheels!!!
those look sweet, big fan of big lips. i would run either 275/40 all around or 275/40 up front and likea 315/35 in the rear.
Old Oct 8, 2008 | 08:37 PM
carguy_z28's Avatar
fan of big lips eh import!? LMAO!!! kidding...
275's in the front will work, barely, I have 275 40 17's and they are pushing it for turning and rubbing,
In the rear, a 315 35 wont work on an 18 inch rim, I have that size on 17's and I have a penny width for room. On an 18 you will rub. You'll have to go to a 295, which on an 18 inch rim will be about as wide as my 315's on 17's.
Old Oct 9, 2008 | 08:43 AM
importmd's Avatar
depending on offset
Old Oct 9, 2008 | 08:51 AM
SpecterGT260's Avatar
Ninja Administrator
is your car lowered? that makes alot of difference.
Old Oct 9, 2008 | 12:30 PM
Mr. Wheel's Avatar
Talk to the Co. that sold me the wheels and they say go with a 295/35/18 on the back and 245/40/18 in the front. Any opinions on these sizes?
Old Oct 9, 2008 | 02:26 PM
importmd's Avatar
i think i would just run 275/40's all around. its nice to have a wide tire up front for better handling, and you can rotate your tires also
Old Oct 9, 2008 | 03:24 PM
Mr. Wheel's Avatar
No not lowered... I think. The offset is 56mm on the rear and 46mm on the front. What are you thoughts on the 295/245 set up?
Old Oct 9, 2008 | 03:27 PM
martybaker's Avatar
The 295/245 setup will work fine, but as he said, then you cant rotate them. Im running 275/40/17's all the way around and I love them.
Old Oct 9, 2008 | 03:31 PM
Mr. Wheel's Avatar
I can't rotate them anyways being that they are 8.5 on the front and 10.5 on the back. Are you saying run 8.5 all around, or run the staggered wheels but same size tires?
