New issue - dying
Well... I have had my 98 for a little more than 2 weeks so must have been due for my 3rd "major" issue.
I went to go to the store just now. Started up as usual then died. Started again as usual and died. Within a second or so of starting. I was able to keep it running by holding the idle at 1k. It wouldn't hold it on its own.
After holding it until it was all warmed up it still died. Tried a few more times of holding it at idle then letting off the gas, died. Then it finally caught itself.
Drove around for a bit. Shut it off. Restarted, its fine now. GREAT. The best problems are the ones that don't repeat itself. I just hope it gave a code for me to have checked tomorrow. My CEL is burnt out so I don't know if that is "on" or not.
Anyone had this issue? I don't believe this is related to my last issue. Which was wiring harness on back of ignition modules loose causing no start. That hasnt happened since. Wouldn't have anything to do with it holding idle.
Is this common? Solution?
Did it happen to rain a lot before this issue occurred? I had this happen in my 2000 S-10 ended up being I had a bad relay that was getting moisture in it when it rained out and it would do the exact same thing. It happened awhile ago, I will have to look back to see which one it was.
ok its been hot as hell here for 3 days no rain. did it again today after i had driven for 15 minutes or so. i then shut it off, went into store and it did it when i went to leave. only took a minute or 2 for it to start holding idle this time though.
If the chip in your key is bad this will happen. Mine did this. If your resistor in the key OR the wires that it connects to break or go bad, it'll shut off the fuel pump for security reasons and your car will sputter and die. Those wires get old and worn out and loosen up or break. if its just loose you can usually jiggle the steering wheel to get a good connection. This doesn't permanently fix it tho. Also could be your crank sensor. Does the security light come on when it dies? and does it sputter to a die or does it just shut off as if you're turning off the key?
