New HELP NOW VERY IMPORTANT
Ok i went to the camaro today and went to start it And i got a security light and the car wont even try and start was running fine before what has happened and how do i start the car. My keyless entry had long died and i normally use the key i think someone said i could lock and unlock it and it would start it didnt work any other ways
RE: New HELP NOW VERY IMPORTANT
I guess you all missed the fact that the security light is on, which would indicate the VATS is keeping him from starting it. I would try and disconnect the battery for a while, hook it back up, and try to start it again. If that doesn't work, then I would looking to getting a new key or ignition cylinder.
I guess i got lucky i went out about an hour later and it started right up but going down the road the light came back on i cut it off and started it again with no problems btu the light seems to want to stay on now when i start going Thanks for the help
