New alternator not charging??
Old Jun 11, 2013 | 09:44 AM
i think it was, just didnt have the key on.
Originally Posted by djsquare1
I tried testing the voltage at the wire from the pcm to the connector but that gave nothing unless it's a ground??. The battery is showing 11.36v when running.
Old Jun 13, 2013 | 12:30 PM
djsquare1's Avatar
The new alty was faulty I guess, no power coming from the rear wire. The connector was fine.
I just installed the old alt and it works perfect for now, the voltage just fluctuates a bit pulsating the headlights at night- no big deal which was my original problem with it. They are sending a replacement with the correct pulley and computer tested. Hope it works!
Thanks for all the help guys, now I know how to test the new alternator that will eventually come in.
Old Jun 13, 2013 | 12:59 PM
Sometimes new doesn't mean flawless, which is why you want to start with checking the basics, at the alternator then work your way out to the wiring. Sounds like your current voltage regulator is funky. As long as it stays above 12 volts.....
Old Jun 13, 2013 | 02:53 PM
djsquare1's Avatar
The dash voltage does not fluctuate much, maybe between 12-14v. Tesing the battery with my DMM does show a slight fluctuation that could be the cause of the headlights pulsing. Ill wait for the warranty return and see how it works out.
Thanks again for all your help, I have a much better understanding now.
jlala
Oct 21, 2009 06:36 PM
chadriley5
82-92 V8 Tech
May 23, 2009 08:55 AM
chadriley5
82-92 V6 Tech
May 22, 2009 11:47 PM
tode5tool
Dec 18, 2008 09:25 AM
ben50520012000
Apr 3, 2007 06:20 AM
