need help fast
Old 11-30-2014 | 04:29 PM
Get a photobucket account and post a link to it. The more people that see it the better. Problem with movies is the sound is never that good and it is hard to pin point where the origin of the sound is coming from.
Photo and image hosting, free photo galleries, photo editing
If you post as an image it should work like below.
Old 11-30-2014 | 04:58 PM
CarolinaCamaro's Avatar
okay i did and yea the sound does suck but at least u get to see how the motor is acting.
Old 11-30-2014 | 08:56 PM
Well it sound like a mechanical failure of some sort. I would do the compression test on cylinder 3. Valve spring failure is very rare but at this point you should be hoping that is what it is. Anything else that would make that kind of noise is going to mean a major engine repair.
Old 11-30-2014 | 09:26 PM
thanks man i just went out and got a compression tester from auto zone. ill let u know what it reads tomorrow.
Old 12-01-2014 | 09:52 PM
okay im not a mechanic. i did the compression test and it read 0. but when i first did it i just took the plug out and plugged in the tester. i knew that was wrong. so i looked up a video and i made it were my engine would not run by unplugging wires and coils. and it still read nothing. so am i still doing it wrong or does that mean something?
Old 12-03-2014 | 07:57 PM
You are cranking the car with the starter?
Old 12-07-2014 | 12:20 PM
yea. cylinder two has 170 psi and cylinder 3 still shows no psi at all.
Old 12-07-2014 | 12:41 PM
160 psi for cylinder 1 still nothing on 3
Old 12-07-2014 | 12:58 PM
cylinder 6 150 psi
  #20
Old 12-07-2014 | 02:04 PM
okay all done. cylinder 3 - 0 psi
2 - 170 psi
1 - 160 psi
5 - 150 psi
4 - 155 psi
6 - 90 psi
i didnt put the spark plugs back in as i went i wasnt sure if i had to.
