need help fast
Old Nov 23, 2014 | 05:47 PM
CarolinaCamaro's Avatar
Default need help fast
so i was going on a trip about 3 hours from my house in my 99 v6 camaro. the only code its ever thrown is the po420 which im pretty sure cause theres no cat. but about a hour and a half into the trip my check engine light started blinking. i pluged my hand held comuter up to it and it said cylinder 3 misfire running a lil bad. so i was going to stop at a parts store thinking it would be a spark plug or wire or coil. as i kept driving it got worse felt like i was on 5 cylinders. i changed the coil and the plug for the cylinder. but did nothing. i havnt changed the wire but the wire looks fine and they were new when i got the car. i managed to drive it home but if u go under 10 mph it will cut off. i had to put it in nutral and rev it up at red lights to make it home yea imagine that on a hour and a half trip. any clues?
Old Nov 23, 2014 | 08:27 PM
injector maybe
Old Nov 24, 2014 | 06:21 AM
How do I check that.
Old Nov 24, 2014 | 08:34 AM
need to pull it and have it cleaned and flow tested. pick up a injector noid light and make sure its being told to fire. what did the plug from that cylinder look like?
Old Nov 24, 2014 | 12:27 PM
torque_is_good's Avatar
or, swap with one from another cylinder. That only shows if the problem follows the injector but process of elimination is a good thing
Old Nov 24, 2014 | 02:07 PM
The plug looked normal
Old Nov 24, 2014 | 02:10 PM
Swapping them out does sound like a good idea. I'll try that and see what it does.
Old Nov 30, 2014 | 12:39 PM
sorry it took me so long to get back on i work alot. this sunday i went to pull a aparts and got to injectors off a 3800 series 2 motor. and it didnt fix it. i got a video of how its running and the only codes its throwing is p0420 and a cylinder 3 missfire. maybe something in the motor is screwed. bent rod or rocker arm? the oil pressure is really high too.
Old Nov 30, 2014 | 12:55 PM
Compression test might be in order. How is the coolant level?
We have seen a few exhaust valve springs break. The will cause the engine to run terrible and is normally a all or nothing, meaning the car goes from running fine to running like crap instantly.
Old Nov 30, 2014 | 01:03 PM
the coolant level is good. if u want to see the video i can email it to u but this site wont let me post it. it exceeds the data u can post or something.
