need help for 93 z28
Old Jun 23, 2010 | 07:05 AM
diablo's Avatar
Default need help for 93 z28
I have a 93 z28 and i am have problems figuring out why i cant run the 1/4 mile any faster than 15.3, but every other camaro i see run at the track will run 13 and faster. I have cam work, 4.10 rear end, 3500 stall converter, also have slicks. anyone have any sugestions on making it run or what to look at that might be holding it back, but when i am on the street it seems like it has alot of power behind it.
any help will be helpful
thanks
art
Old Jun 23, 2010 | 10:00 AM
Stix80's Avatar
do you have exhaust intake or anything like that and what do the other camaros have done to them
Old Jun 23, 2010 | 10:01 AM
please list all your mods. do you have a good cai? what brand? have the heads been p&p'd? what cam? what injectors? has it been tuned? if so where? etc
Old Jun 24, 2010 | 06:40 AM
diablo's Avatar
k&n cold air intake, not sure of the cam was done before i bought the car, also has
a flowmaster exhaust with now cat.. has not been tuned.. the only thing all of them told me was exhaust and cold air
Old Jun 24, 2010 | 09:21 AM
have you had it scanned to see if theres any trouble codes stored? you could pick up a aldl cable from moats and download datamaster, make sure you have the right memory and all on your computer. then you could see whats happening in the system. what rpms are you hitting at the finish?
Old Jun 24, 2010 | 03:40 PM
diablo's Avatar
about 5500 rpms in third, i have no codes in the system, do you guys think it might be the fuel to air ratio? i really dont know what else to try
Old Jun 24, 2010 | 04:12 PM
Massey's Avatar
With cars like this there is alot that goes into making good times. You cant just change stuff and have everything else work well. New cam means time with a computer tuning your engine, new injectors... computer... new gears... yup back to the computer. Your new gear ratio may be throwing the shift points of your tranny off. You have a 4L60 or better known as the THM700R4, this tranny is completely mechanical with its shift points so changing the rear gears can effect the governor which lets the tranny know how fast the driveline is spinning. You need to take the whole car into account when you are talking about a new vehicle and racing.
Massey
Old Jun 24, 2010 | 06:58 PM
diablo's Avatar
so what your saying is change the cam so i know what is and have it tuned for it and change the the gearing in the tranny
Old Jun 24, 2010 | 07:40 PM
You cheapest easiest fix is to take it to a shop the dyno tune fuel injected car. It will cost between $250-$400. My guess would be something is wrong its not just the mismatch of parts you have. With out the proper tune the part your added should not hurt you times.
Just a wild guess but either a pluged Cat or a streched timing chain. The tuning shop should be able to figure any of those issue out pretty quickly.
Old Jun 25, 2010 | 06:23 AM
diablo's Avatar
ok i guess that will be my next step thanks for the help
