Need help!!!!
Old Oct 26, 2011 | 10:23 AM
350camaro85's Avatar
going to do alot of tests today and see starting with the injectors. the motor was a reman from the factory so timing should be set already? and i did not have to force anything on so we will see what happens today and i will let u guys know. thanks for the help
Old Oct 26, 2011 | 03:44 PM
I TESTED MY INJECTORS WITH A NOID LIGHT AND NOTHING NO LIGHT FLASH NOTHING. SO I GUESS I FOUND MY PROBLEM, MY INJECTORS ARENT PUSHING MY FUEL. SO HOW DO I FIX NO POWER GOIN TO MY INJECTORS? GROUND? BAD pcm?
Old Oct 26, 2011 | 08:33 PM
Psycho's Avatar
Check your under hood fuses. There are 2 that are for the injectors. Also check the ground wire that comes down by the passenger side exhaust. It is black with a white stripe. It grounds the ECM.
Unplug the ECM fuse for 30 seconds. That clears the ECM and should provide a clean starting point for diagnostics.
