Need an answer on the top coolant bleeder screw.
Old Sep 23, 2012 | 12:15 PM
Greg08's Avatar
Default Need an answer on the top coolant bleeder screw.
When I have the camaro running to bleed the coolant system should I have this top coolant hose screw open or what? I have full heat blasting running and no coolant or anything comes out of the top bleed screw on the small coolant line. With rad cap on or off. I just filled the engind with water and bled the system. O. I see coolant coming out as I stand over my camaro. I guess nvm!
Old Sep 23, 2012 | 01:17 PM
BasicConcepts's Avatar
Technical User
glad to see you got it figured out. when there was no coolant coming out it was because it was bleeding off the air.
Old Sep 23, 2012 | 07:32 PM
Greg08's Avatar
Tyvm. I think I messed up and may have let air into the system because I didn't have the bleed screw on and had to turn the car off and wait fOr it to stop bursting with antifreeze love before I cOuld reinstall the screw. I failed lol. Tomorrow I'll do he same thing except this time I'll keep the screw on a bit . Wish me luck!
Old Sep 23, 2012 | 07:55 PM
Technical User
lol ya probably a good idea to leave the screw in a little. theres a hole in the side of the bleeder for the air to come out and than the screw seals it up.
Old Sep 23, 2012 | 10:20 PM
Greg08's Avatar
:] yea, first timeworking with this.thank you
greenarrow
Jun 23, 2013 01:10 PM
SanDiegoBert
Mar 17, 2012 12:27 PM
libertyforall1776
LS Series Tech
Oct 1, 2010 01:55 AM
Chevyfan99
Dec 3, 2008 05:45 PM
