Need advice ASAP ( Milky residue in Oil Cap)
Old Mar 10, 2008 | 05:01 PM
kamaro68's Avatar
Default RE: Need advice ASAP ( Milky residue in Oil Cap)
10 out of 10 times in my experience it has been a blown headgasket. There would have to be a TON of condensation in the motor to affect the consistency of the oil to create a milky substance.
Old Mar 10, 2008 | 08:03 PM
ORIGINAL: Lacunaa
Changed out PCV valve and connecting hoses
Valve was completely clogged
You just may have fixed your problem. A clogged PCV will allow moisture to stay in the crankcase and emulsify with the oil and then deposit on cooler surfaces such as the oil filler cap. It would be a good idea to let the engine get fully warmed up and change the oil and filter to get rid of all the slush. If the gunk does come back, then there may be some other problems.
Old Mar 10, 2008 | 08:07 PM
6v49der's Avatar
Even my parents cars have some condensation inside the oil cap from time to time, until it shows up in performance or fluids start mixing and dissappearing I wouldnt worry about it. A good check up of everything never hurt though.
WTFCamaroProblem
2010+ V6 Tech
12
Jan 5, 2014 11:14 AM
rcknrolfender79
Oct 8, 2009 09:13 PM
s281er238
Mar 25, 2008 06:17 PM
