Mystery vacuum line
Old Jul 10, 2017 | 08:06 AM
chud's Avatar
Default Mystery vacuum line
I have a 98 SS. One of the horns went bad. From under passenger front I dropped the plastic and found the bad horn. Also, there is a small vacuum canister, maybe 2" dia by 6" long with a small broken line coming out. The other end goes into a wiring harness by the battery. I lost the line at this point. Does anyone know what it is for. I did patch it with a slightly bigger hose and siliconed the edges. Everything worked before so I did not see any difference.
Old Jul 10, 2017 | 12:27 PM
I am not at home right now , but did you see the manuals in the manual section? There is also a PDF of the parts manual floating around the net.
libertyforall1776
Mar 7, 2009 08:07 PM
alilaw
Oct 18, 2008 08:55 PM
xbdogs88
Jul 9, 2007 09:23 AM
jbassiii
May 18, 2006 04:11 PM
sewerrat
82-92 V8 Tech
16
May 13, 2006 06:30 PM
