My new fuel pump
Okay so my car **** out on me last sunday. I knew the fuel pump was bad so sure enough after testing thats what it was. I used the hatch method* and i must say, after initial testing today my car is running so much better. Airtex fuel pump FTW
* I would personally go a little just a little bit wider on the left and right side incisions if u use this method.
ok i was wondering if those mesurements were big enough. i know ive read of guys going bigger and use the indentations to mount to but none of the pictures i found showed that and the pic i used had measurments to use so a guy had an idea were he could cut and not hit any fuel lines. thanks for the comments.
I have to put a notch in drivers side front so I could get to the connector. Other then that I am very close to the original dimension. When I cut the notch I left one side connected and just bent the sheet metal away. When I was done I bent it back and sealed it up.
