my engine swap progress (3.4 to 5.7)
Old 04-28-2010, 05:30 PM
black95z28's Avatar
you seemed to have gone around the world pretty quick.
  #32
Old 04-28-2010, 07:44 PM
vteckiller's Avatar
I just thought id post up some pics of under that car.
The only part i wasnt happy with is the y pipe. Is this costing me alot of hp?
  #33
Old 05-01-2010, 01:05 AM
cmcz450's Avatar
looks sweettttt
  #34
Old 05-03-2010, 10:55 AM
97camaro89's Avatar
hey i got a quick question about the motor mounts. could you just send me the specs on them. like the overall length of it going both from the kmember up to the engine and over. that would be really helpful cuz im in the middle of this build right now and it would be amazing if you had that info so i could weild up a pair. so im not doing it from scratch.
  #35
Old 05-03-2010, 11:04 AM
97camaro89's Avatar
and if you don't mind could you tell me the money break down like what costed what and what you had to buy
  #36
Old 05-18-2010, 10:08 PM
dayripper's Avatar
hi i am new to the forum. but you can get a MSD front mount distributer to bolt on the front and then you have to get a oil pump shaft.(the bottom half of the dist.)
cost bout 800 for the set up.
  #37
Old 07-16-2010, 05:30 PM
Default engine swap
im just curious on what pacesetters you had on that engine and you had mention that you could use ls mounts and just customize them, but the pic you put up you said was custom mounts. just curious because im currently in the middle of this swap and any additional info would be greatly appreciated. thanks for any info
  #38
Old 07-16-2010, 05:40 PM
DarkKnight's Avatar
GTO Killer
LimeKnight
cool build, almost did it myself, only complaint, some things look a little janky... like the swith panel and gauge panel, if you cleaned up the look of them a little but i think it would make a huge dif
  #39
Old 07-28-2010, 01:23 AM
sbc 98 comaro's Avatar
Hey mate, having a hoist is handy!! I'm keen to see some pics. I need to know how much height i need to remove my standard dizzy with the cap off out of the block at 1 top dead centre. I have a roller cammed 355 in a 98 comaro, and im unsure if i can remove it to swap for an msd unit as mine is along way under the windscreen.
So i need block to capless dizzy measurement, can u help me???
  #40
Old 07-28-2010, 04:14 PM
MelloYello's Avatar
must of been a windy day when you took that video.. camera was like wobbbbble wobbble wobbbbbble
Quick Reply: my engine swap progress (3.4 to 5.7)
