Is my Camaro finally done for?
Old Apr 20, 2014 | 06:52 PM
JPrice's Avatar
Default Is my Camaro finally done for?
Out of no where my oil gauge on the dash is constantly reading 0, but has fresh oil and filter. I was hoping that would fix it, but didn't. The engine sounds louder than normally. Like a mix between a weedeater and a sewing machine? Check gauges light came on, hooked a computer to it and got 4 codes.
p0102 (Mass Air Flow (MAF) Circuit Low Input)
p0113 (Intake air temperature sensor)
p1406 (EGR VALVE PINTLE POSITION CIRCUIT)
p0300 (Random Misfire)
I don't think either of these has anything to do with the oil pressure reading 0 and the car running and sounding like crap.
Is this a sign of a dead/failing oil pump or motor being shot?
It does have 190,000 miles.
It's a 97 v6 3.8 automatic.
Old Apr 20, 2014 | 07:03 PM
check for plugged cat. check for shorted or damaged wires in the engine compartment.
Old Apr 20, 2014 | 09:29 PM
First pull your oil filter, don't spill it out. Dip your finger in the hole and see if there is shinny specs in it. If there is a lot of specs you motor is most likely done for. Second would be to verify the zero oil pressure with an manual gage.
Bluegixxer1k
Jul 24, 2011 05:51 PM
xXChipXx
Jul 25, 2010 07:19 AM
95_camaro_son
May 31, 2008 09:21 PM
socalkid13
Mar 27, 2008 08:45 PM
soupah
Feb 9, 2008 06:59 PM
