My 94 Camaro is Squealing.... HELP!!!
Old Jun 27, 2007 | 01:17 AM
blakoma's Avatar
Default My 94 Camaro is Squealing.... HELP!!!
I have a 94 Z28 and it squeals like crazy when i'm at a low RPM or when I go over bumps. It has new struts and I have replaced the sway bar mounting brackets because they were all bent up when I got the car. The only thing I can think of from here is ball joints - end links - or tie rod ends. I'm really hoping that it isn't a problem with the control arm. If it's any consellation I just replaced the water pump and the noise started shortly after that. I have zero power loss and it does not happen above 2000 RPM's. The front supsension, though, is very noisy altogether. Does anyone know what this might be or are experiencing the same problems?
Thanks - B
Old Jun 27, 2007 | 01:31 AM
CRanMaro99's Avatar
April 2008 ROTM
Default RE: My 94 Camaro is Squealing.... HELP!!!
It is hard to see it as a suspension/chassis issue suck as sway bar/ball joints/end links etc. It wasn't the case in my last vehicle.
The fact that it doesn't happen above a certain rpm is weird. Does it make the sound while going over a bump when revving about 2k rpms? Try it out?
Old Jun 27, 2007 | 06:42 AM
bluovlh8er's Avatar
what about front brakes?
Old Jun 27, 2007 | 08:23 AM
blakoma's Avatar
Yes it does over bumps. I even tried to move the cold air intake around because I tought maybe it was rubbing somewhere and nothing worked. That's why i was worried that it may be a suspension part because I have no power loss at all.
Dana
Sep 23, 2013 11:37 AM
Big Zeus08
Oct 4, 2012 03:29 PM
Guitar
Jul 17, 2011 09:51 PM
stillettoDSM
Sep 15, 2009 08:18 AM
dhill
Sep 23, 2008 08:16 PM
