My 01 SS Vert Build Thread
Old 07-16-2010, 05:06 PM
Josh40601's Avatar
Originally Posted by libertyforall1776
For an SS, I would save up for them then... You will be glad you did later...
How will they hold up with the system though? Why go and spend almost a grand for shocks and struts when the weight of the stereo in the back is going to deteriorate the **** out of them?
  #22
Old 07-16-2010, 05:09 PM
Josh40601's Avatar
Originally Posted by RedKnight
Your car is awesome, BTW. I'll be looking forward to any updates you post. What size tires are you running? 265s or 275s?
To answer your question about tires, I am running 275/40's up front and 285/40's out back. The tires out back are coming off as they are super bald, so I will most likely go back to the stock 275/40's. The car Summitomos up front, so im going to match them out back
  #23
Old 07-17-2010, 10:19 PM
libertyforall1776's Avatar
LOL, seriously?! How much weight could you possibly have in a stereo?
Koni's are adjustable, so you dial-in what you need. Plus lifetime warranty. Strano had a set of four Koni SAs on sale for $850 shipped -- not a bad price for Konis.
  #24
Old 07-19-2010, 09:03 PM
snugz13's Avatar
how much does your system weigh? not highjack your thread but ive been wondering how much mine weighs also. 2 12s and 2 amps.
  #25
Old 07-19-2010, 09:57 PM
RedKnight's Avatar
Cool. I was just curious since I see many people running a little wider tire out back than in front. When I bought my last set of tires, I went 275s all the way around. I'm considering buying lowering springs but was concerned about the 275s up front rubbing.
  #26
Old 07-20-2010, 01:16 AM
sbc 98 comaro's Avatar
Hi mate, nice car. That bodywork is KILLER, what a find. How many miles? Car might go good, but a nice set of pipes, a decent air intake, and a nice tune would have her making crisper power and even better fuel economy!!!
Keep that in mind, i will be keeping an eye on the build. BTW the hurst gear leaver and what we call them the rip shifter here looks nice.
However just a personal thing, over here the fashion, is the cut the gear leaver down in height for a even tougher, cleaner look, my two cents.
Thanks mate cheers ben.
  #27
Old 07-20-2010, 09:50 AM
Josh40601's Avatar
not quite sure. The most of 100 lbs.
  #28
Old 07-20-2010, 09:58 AM
Josh40601's Avatar
I have the Eibach pro kit on mine and have no problems what so all with rubbing up front. Out back you can see where the tire has rubbed the inside of the fender well. The bumpstops out back are also about a half inch from the sidewall in the rear. I'm going back to 275's all the way around.
Thanks for the kind words. The milage is pretty high at 135k, but once I get the car restored, I don't think the milage will be too much of a hassle if I ever sell it. I have a Flowmaster dual chamber knock off already installed, and once I get everything back together, I'm looking at either a K&N or Valant intake, then maybe a Diablosport Programmer. Nothing more. As far as the shifter, that sounds like it would look great, but I have no idea where to start. Maybe you could give some tips on how to do it or paste up a link?
  #29
Old 07-21-2010, 12:50 AM
Well the Owners Manual states "Don’t carry more than 100 lbs. (45 kg) in your rear area."
You should also check out the Gross Axle Weight Rating (GAWR) on the Certification label, and see the Tire-Loading Information label (both on rear edge of the driver’s door).
  #30
Old 07-21-2010, 08:26 AM
Josh40601's Avatar
I'd say the setup weighs in around 65-75 lbs.
Quick Reply: My 01 SS Vert Build Thread
