Ms3 Cam
To make this possible you need a set of .650" lift dual valvesprings and a set of hardened pushrods. Get in touch with Texas Speed to see what the piston to valve clearance is as you may need to flycut the pistons for safety.
all you need is a tune and the valve springs to run it, if you want to run it at its peak youll need rods and all that
i know a guy running 10.80s on a ms3 cam, springs, ls6 heads, ls6 intake, 100 shot, and exhaust
Nice! I would like to see that car!
