misfire
after i get up to speed, anywhere from 45-50 in overdrive i try to accelereate slowly and the car will buck and sometimes backfire. if i accelerate a little harder it wont do that anymore. probly a dumb ? but is it still misfiring when im WOT even tho its not bucking? and could that be the reason y im losing to stock TAs?
It may be that the opti crapped out, but before chenging it, you may want to check out all other ingnition stuff, including plugs & wires, and also check the fuel pressure. Dump a couple of cans of injector cleaner into the tank.
