LT1 will not rev with WOT
Old Jan 28, 2011 | 12:35 PM
ampprc's Avatar
Default LT1 will not rev with WOT
When i go to start the car it idles kind of rough. i have changed fuel pump, fuel filter, opti has about 3000 miles on it, just replaced the coil, new plugs, new wires. could it be my tps?
Old Jan 28, 2011 | 09:59 PM
check to see if the iac valve needs cleanin. check wire connector on it too.
Old Jan 29, 2011 | 01:14 AM
ampprc's Avatar
Why would the IAC valve cause it not to rev up?
Old Jan 29, 2011 | 03:26 AM
Massey's Avatar
the IAC will cause the engine to run rough at idle. The TPS could cause the engine to stumble, use an ohm meter to check to see if there are any dead spots. Did this problem just start or has it been around for a while? If it has been around since the engine mods I would look to see if you have proper fuel pressure for WOT running.
Massey
Old Jan 29, 2011 | 06:08 AM
Have you checks for a plugged Cat?
